just want to share something at my blog..
Here is the tweeter..pioneer TS-T35
it's an old model actually..very2 ol skool..
take a look at the pioneer logo...
still using old logo..haha..
so, i play to install it by myself..some tools that i need are..
* some wires
* wiring tape
* screwdriver
* cutter
1, what u need to do is take out the silver color as what i;m mentioned in the pic below..
please be careful doing this....
Ops! maybe because I'm gopoh..1 of the clip is broken..
eheh..
its OK..just a small metter..:D
after that, take out the round thing at the pic below
you'll see a screw below it..
unthight that screw and take out that part..please be careful..it's quite tight actually..:D
after that, take out the door trim start from the below..
at the upper side, just pull it out..
(it's just like a hook actually)
and you'll see as the pic below
please do not try to open the plastic to prevent short circuit..:D
try to find the wires that connect to your front spaeker
it got 2 wires..a green and red colour..
try to cut the wire cover using cutter just like the pic below..
please try not to cut the wires....:)
attach the tweeter wire and fold it with wiring tape
before you place back your door trim, kindly please check back all the things is work perfectly..including your front speaker and your power window switch..
same goes to the other side of the door..
ok its done..
it will be more elegant if i tebuk and do just like as a built in tweeter..
but, i think its better as i leave as it is..
PS: if you think u cant do, just send it to car accessories shop..:)
