S SatanicsM Known Member Senior Member Joined Mar 12, 2005 Messages 108 Points 3,016 Nov 28, 2007 #1 hey..currently i'm using daihatsu move l9 turbo engin 3 cylynder when i acclerate above 120km/j my check light on y ah?
SkYwAlKeR Over 10,000 RPM! Senior Member Joined Mar 12, 2005 Messages 10,139 Points 5,183 Location ePoh ~ malacca Nov 28, 2007 #2 means got problem with ur engine...
ACQ2305 500 RPM Senior Member Joined May 25, 2007 Messages 988 Points 1,543 Location HeadHunters Nov 29, 2007 #3 at least wen u accelerate den cme out, mine everytme wen i start my car, it goes off 4 abt 20 seconds, n den cmes back... had 2 change d whle ECU. btw,using 4G91 engine... dne so many things tat tot effected it,bt it was d ECU in d end..
apai_Ngage Known Member Senior Member Joined Dec 15, 2004 Messages 337 Points 3,018 Dec 8, 2007 #4 Try checking the wiring to the ECU as the wiring socket to the ECU might not connected well or has loosen.
B boyzone 2,000 RPM Senior Member Joined Mar 13, 2005 Messages 2,668 Points 5,148 Dec 9, 2007 #5 lossen on sensor socket might cause u this problem.
S SatanicsM Known Member Senior Member Joined Mar 12, 2005 Messages 108 Points 3,016 Dec 9, 2007 #6 wat sensor?o2?exhaust? or maybe the sensor is damage?>
