Im running on a daihatsu L9 3 piston 660cc.. With a RHF4.. Any suggestion wat type/brand of fuel regulator n fuel pump should i use? Btw, im a newbie.. ;)
1 bar.. But nw i turned it to standard boost.. Because when i turned it to 1 bar, it seems the turbo is struggling to build pressure.. The boost meter is creeping slowly to 1 bar..
last time i use RB20DET fuel pump. its not a direct clip to stock fuel pump, but not much to mod. the size is bigger than stock but still can fit at the stock fuel bracket. some of my frens also use gsr fuel pump.. but not sure need to mod or not.. don't forget to get a fuel regulator as well before installing bigger fuel pump bro..
hye guys... my ayc is currently in bad shaped... im driving 7.5 gta... it have a strong vibration to the car when reach 75kmh... actually can hear some noise from it... noise came from the connection between right...
