BRISK spark plug
BRISK spark plug
assasin
100% Brand NEW in BOX.
- 100% Original
- Made In Czech Republic
- BRISK Silver Spark Plug
- Price Quoted For 4pcs.
- Installation can be arranged.
- We absorb GST 6%
- Available for proton, perodua. honda, toyota, mazda, nissan, hyundai.
14mm thread, 3/4"(19mm) reach, 5/8'(16mm) hex, gasket seat, non-projected tip, RESISTOR, fine wire 1.5mm Silver center el., cut-back ground electrode BRISK Silver Racing spark plug was specially designed for modified, turbo, supercharged, or nitrous-fed applications where engine control modules or engine management systems are extra sensitive to electromagnetic interference.
Brisk Silver Racing plugs have a better ignitability than conventional performance spark plugs, and offer better performance and reliability in high boost, nitrous or high compression applications. Silver is an element with the most free electrons, and is the best electrical and thermal (heat) conductor of all metals! Better than gold, copper ...and many times better than Iridium. The Brisk Silver Racing plugs have a fine wire center electrode (not just the tip), which gives more room for insulator between the center electrode and spark plug shell. More insulation results in a durable spark plug with high dielectric strength - the most important spark plug parameter in forced induction applications.
In street applications, the greatest advantage is a powerfull spark, improved performance, low ignition voltage requirements, excellent heat dissipation at full load and excellent anti-fouling resistance under light load operation.
