[After12]Genuine DENSO Iridium Spark Plug
MAX_TorQue
7,000 RPM
Welcome to AfterTwelve E-Garage!!!
We do shipping internationally / COD / Credit card accepted.
We provide installation and painting as well.
Some item's price quoted below including installation or painting.Please take note.
Any kit that you are interested but not listed here, please contact us.
For order/enquiry, please contact JACK 012.312.7113.
Pls click to Visit After Twelve E-Garage
WHY buy from us:
-Authorized dealer for Denso Spark plug.
-100% GENUINE product from Denso. Money back guaranty.
-Free installation and consultation.
-Dealers / workshop / car club welcome.
Iridium Power is recommended for the following kind of user.
“I want the next level of response and power for my baby”
For drivers that care about performance:
By using a 0.4mm diameter iridium alloy center electrode and a special ground electrode, IRIDIUM POWER realizes spark performance unseen until now. It steadily gives a high level of response under a variety of driving conditions. The result? Increased acceleration and torque compared to regular plugs.
“It’s the car that I drive every day, so I want less fuel consumption.”
For drivers that care about mileage:
If you use your car on a daily basis, you may be concerned about fuel consumption. IRIDIUM POWER is one solution.
Benefits of installing DENSO Iridium Spark Plug:
Ignitability That's a Cut Above
-With DENSO's very own U-Groove ground electrode for better spark performance.
To increase ignitability, the important point is to let the flame kernel caused by the spark to grow to a large size. Normally, this can be accomplishing by widening the spark gap, however this causes spark voltage to increase, which has the opposite effect. IRIDIUM POWER uses DENSO very own U-Groove ground electrode to realize a superb ignitability while maintaining spark voltage at low levels.
Improved Horse Power(1)
-Get more power with an optimal combustion cycle.
IRIDIUM POWER has a low required voltage and a high ignitability, resulting in less misfiring and no spark, the outcome being a dramatic improvement in combustion. Engine output is thus increased. The findings of a bench test using a motorcycle engine to show the improved combustion from IRIDIUM POWER is shown on the below. Compared to normal plugs, a 0.5ps (1.4%) improvement is seen in output at 110km/h.
Improved Horse Power(2)
-The 0.4mm center electrode increases output under various driving conditions.
The power produced by the 0.4mm dia. iridium center electrode is IRIDIUM POWER unmatched by other plugs. The graph below compares the resulting power when IRIDIUM POWER is installed compared to other high performance plugs. Using a 0.4mm dia. fine center electrode, there is more power compared to 0.8mm and 2.5mm dia. plugs. This is what makes the difference in acceleration and in your lap time.
Improved Acceleration
-Increased response and acceleration performance.
IRIDIUM POWER best demonstrates its performance improvement during acceleration.IRIDIUM POWER has a 0.4 mm diameter iridium center electrode and a specially shaped ground electrode. These features combine to achieve higher ignitability and require lower spark voltage than ever before. This enables high-response driving with fewer misfires than under higher required voltage spark conditions, and fewer misfires when ignitability is difficult. As a result, acceleration improves in comparison with normal plugs.
Improved Fuel Mileage
-Even during idling ignition is assured, with less fuel consumption and less noise.
The good ignitability from the fine electrode (0.4mm) of IRIDIUM POWER draws out much more performance from the engine. Comparing a normal plug (W20FS-U) with an IRIDIUM POWER(IWF22) on a 2 cycle 50cc engine, fuel consumption improved from 41.74km/L -> 43.69km/L, an improvement of about 5%.
Note: Mileage measured using a chassis dynamo; actual driving results under normal conditions may vary.
Models available for:
-IQ20 / IQ22 (Suitable for Toyota 4age)
-IK20 / IK22 / IK24 (suitable for mostly of the car models)
-IT20 / IT 22 (Campro Engine)
-IK20L (Honda K-series engine)
-IK01-27 (Mazda Rotary)
-etc.
Others:
DENSO Iridium Tough - HERE
DENSO Racing Spark Plug - HERE
Pls contact JACK 012.312.7113. for more information.
Please visit our showroom for more discount!!!
4G91 use which type of spark plug? is it IK series? price per piece or per set (4 nos)? Price plus delivery to JB?
