Blox ITB Honda B16 B18 Type R
D`s Garage
7,000 RPM
BLOX Individual Throttle Body (ITB)
Silver with Blue Rail
Application:
Honda B16, B18C & Type-R
Will Not Fit Non-Vtec or GSR
45mm Opening , 48mm Horn Buttefly
Product Description:OBX individual throttle body kits improve engine response and power output, through the use of one throttle body per cylinder. Effective tuning per cylinder not compromised tuning with only one throttle body.
Qualities:
Reduce air volume within the manifold and improve acceleration response
Super response - The improvement of the accelerator response is due to the reduction in volume of air within the manifold
Straight induction ports
Each intake is made the same length
2.0" Inlet and 2.0" Outlet (Oval)
Increased power - Improved induction efficiency gives the engine the correct quantities of air/fuel on demand
48mm Butterfly Type 4 Throttle Body
ITB inlet are CNC machined from billet aluminum solid piece
Airflow bench tested trumpet
Bottom & mid range Torque increase - Each cylinder receives a fuller charge of air/fuel especially at low to mid engine speeds. This is due to the independent throttle bodies and more effective injector positioning
Design and Quality of BLOX U.S.A
Selling at RM 1xxx
Interested please contact us @ [email protected]
We are located in Bandar Sunway opposite Sunway College.Behind Works Engineering & N1 Racing
Same row with ATS Plus & Trial Performance
D`s Garage
No.37,Jalan PJS 11/9
Bandar Sunway 46150
Petaling Jaya
012-2206117 (MATT)
016-9973300 (DENNY)
Check out our D`s Garage sales item.
Find us in Facebook D`s Garage.
