BLOX Individual Throttle Body kits
powerautohauz
((( God Level 30,000 RPM )))
BLOX Individual Throttle Body kits improve engine response and power output, through the use of one throttle body per cylinder. Effective tuning per cylinder not compromised tuning with only one throttle body.
Description
- Reduce air volume within the manifold and improve acceleration response
- Super response - The improvement of the accelerator response is due to the reduction in volume of air within the manifold
- Straight induction ports
- Each intake is made the same length
- 2.0" Inlet and 2.0" Outlet (Oval)
- Increased power - Improved induction efficiency gives the engine the correct quantities of air/fuel on demand
- 48mm Butterfly Type 4 Throttle Body
- ITB inlet are CNC machined from billet aluminum solid piece
- Airflow bench tested trumpet
- Bottom & mid range Torque increase - Each cylinder receives a fuller charge of air/fuel especially at low to mid engine speeds. This is due to the independent throttle bodies and more effective injector positioning.
Application:
- Honda B16, B18C & Type-R
- Will Not Fit Non-Vtec or GSR
- 45mm Opening , 48mm Horn Butterfly
Bakuso Racing Sdn. Bhd.
No.21, Jln PJS 11/24,
Bdr Sunway.
47500 Subang Jaya.
Land Mark:
Desmond 017-396 8567
Email us : [email protected]
