not much point. if you want an individual throttle on the 4afe, first, the cheapest ITB you can find is the one from 20v 4age. secondly, they don't fit, so you heed a custom made adapter (or any off the shelf unit if there is any), would cost a couple of hundred, unless you do it yourself then its cheap (provided you know how). thirdly, you will either get the BT ecu or other third party aftermarket ecu, which will either cost you hundreds or thousands.Shinda said:HMM N/A Ripping sounds means.... :D are the intake manafolds on a 4A-FE and Black Top 4A-GE the same? thinking of getting trumpets for my engine then when i can afford the 20v BT i change straight over.
Sorry I don't know shit but learning fast :P
thanks guys
so, if you want to let ppl see that you got 4 musical instrument under the hood best just get a 6 speed blacktop halfcut and transfer everything over.
[/URL...
