if wira with 4wd its quite easy to spot, but if perdana with 4wd, a little bit difficult to spot, because the rear bumper is abit labuh......JPJ officer has to really bend down & look under the car to spot the shaft.....
Hie All,
I'm expected to get the Manual White Neo CPS before Chirstmas, but would like to know some advise as below on the maintainence and some questions. Hope some Neo CPS or other forumers feedback on my questions below, Thanks!
1st: Jerking problem on the 2nd and 3rd gear for first batch CPS seems to be common, about the batch im getting consider 2010end car anyone here experience the same problem? If still with the same problem what at the preventive messures or things i should do to stop the jerking?
2nd: What kind of engine oil suits the CPS engine as im planing to use aftermarket oils for the first change?
3rd: Notice the 16"rims are using 195/60 tyres, if were to change the rims will the warranty be void?
4th: Anyone here knows the R3 stage1 and stage2 mod's price for the CPS engine, plus what are the parts included for both stage?
5th: If were to do the tuning and modfication other then R3 where can i find a good workshope who knows how to do Campro engine?
Currently these are the questions running in my mind, hope some of you may share your experience or knowledge on the matter above.:wavey:
