Waja CPS recommended or best engine oil
-lanz-
Perak/Kedah
Hi guys,Despite there were a lot of discussion had going on with engine oil,i would like to know from Waja CPS owners.
What is the best engine oil for CPS engine?
Which one is better mineral,semi or fully?
Buy what your pocket can afford. Best sure is FS, but for your NA Waja, SS good enough. Just follow the correct viscosity recommended and do oil change on time...:driver:
Best engine oil? You can afford or not? I cannot.
Motul 300V has the best base stock engine oil.
Pennzoil Platinum has the best cleaning addictive.
Mobil 1 has the best overall accreditation and approvals from manufacturers, and is 1 of the most used factory fill for performance vehicles from the factory.
Shell Helix Ultra got the best bang for bucks, occasionally.
Basically, just choose a major international brand. Fully synthetic. And you'll be fine.
As I mentioned many times before, just go to Tesco/AEON and buy which ever of the branded oil on big promotion! :biggrin: If can afford FS and your recommended OCI is 10k km then go for FS. If not then semi synth also enough.
