thanks for all your suggestion guys, and i appreciated much. it seems like high fuel consumption if equipped with turbo or supercharger. is there any other suggestion just to have a slight modification to boost up the power without severely damaged the engine 1NZ-FE for the long run? i might search something practical with optimum engine output as well as best engineering practice for engine modification. most probably one of you has an expertise to look it in macro and micro point of view.
through out all heavy thing in your car. more lighten more pick up and save petrol.....:sleep:
if u want more pick up and speedy for sure more fuel needed. small thing u can do like change air filter to power filter like k&n maybe 1 hp increase or change exhaust system 1.5hp increase + fuel increase change new power plug cabel and performance plug 1hp increase or u buy power air compressor 1hp increase save fuel a bit. total not more than 4-6hp (approximately). but if u want more hp just plug the supercharge or turbo. for sure u will interested with those thing. correct me if im wrong sifoooooosss....
Where can I order this piston ?? which shop recommend ??
I dont want go for Wiseco Piston because.. sleeve required !
And..Mahle Piston just drop in and no need sleeve the block...
If changing those forged...
I am a 03 350z auto and I have some clunking noise that comes on when i acclerate the vehicle, this is especially happens when the gears downshift and also happens when i am going up some hills, does anyone know the...
