WTS: Zaptor Silver Edition II for RM50
kelfo
Bukit Bintang
Dear Fellow Car Members,
We like to Introduce to you our Latest Zaptor Silver Edition II Retailing at only RM50.00. Free Installation is Provided within the Klang Valley Area. :driver:
If you need further details, please contact us at 016-3808883.
HERE ARE SOME OF THE BENEFITS OF INSTALLING A ZAPTOR VOLTAGE STABILISER...
TO IMPROVE THE CAR'S ENGINE PERFORMANCE, THE CAR'S ECU IS HIGHLY DEPENDENT ON ALL THE SENSORS THAT PROVIDE DATA SIGNALS TO COORDINATE DIFFERENT PARTS OF THE CAR. THE ECU WILL PERFORM BEST, WHEN IT RECEIVES AN ACCURATE AND STABLE ELECTRICAL SIGNAL. HENCE AN ACCURATE & STABLE ELECTRICAL SUPPLY WILL ENSURE BEST TORQUE & RESPONSE.
INSTALLING THE VOLTAGE STABILIZER WILL ENSURE IMPROVED POWER RANGE RPM, TORQUE & IMPROVED ACCELERATION. IT ALSO ENHANCES THE AUDIO, LAMPS & ALL OTHER EQUIPMENTS TO THEIR MAXIMUM POTENTIAL.
BENEFITS:
  • INCREASES TORQUE
  • IMPROVES FUEL ECONOMY
  • IMPROVES ENGINE RESPONSE
  • STABILIZES IDLING
  • EASIER ENGINE START
  • LESSER ENGINE NOISE
  • INCREASES HEADLIGHT BRIGHTNESS
  • IMPROVES BATTERY LIFE & AUDIO QUALITY
THIS VOLTAGE STABILIZER STORES & HOLDS ELECTRICAL ENERGY AT ALL TIMES TO PROVIDE STABLE & SUFFICIENT ELECTRICAL ENERGY WHENEVER THERE IS VOLTAGE DROP ACROSS THE SUPPLY WHEN POWER NEEDED TO ALL PARTS OF THE CAR.
THIS SYSTEM CAN FILTER OUT ELECTRICAL NOISE & ELIMINATE IRREGULAR CURRENT FLOW IN THE CAR ELECTRICAL SYSTEM.
ITS SO EASY TO INSTALL, JUST CONNECT THE RED WIRE TO BATTERY POSITIVE & BLACK WIRE TO BATTERY NEGATIVE.
http://zaptor.webs.com/
From this coming Thursday onwards 9th, 10th, 11th and 12th...
We would be in Bukit Merah Laketown Resort or Bukit Merah Highway R & R...
Those from the Northern Region wish to COD with Installation, please inform us in advance so we can meet up!!! YamCha!!!
Contact us at 012-5394888. TQ!!!
