(WTS) Stiff Ring
(WTS) Stiff Ring
eowk_3456
kl
(WTS)Stiff Ring/Rigid Collar - Dworks Garage
Improve Handling, Reduce Noise, Eliminate Vibration
Stiff Ring made of special formula aluminium which used in aircraft frame building. It used to correct the car body basic geometry by filling the gap between the sub frame bolts, sub frame and the car body bolt hole. Car engine, transmission, suspension and the body shelf are mounted on the sub frame. Thus, correcting the geometry setup with Stiff Ring, the car handling will be improved significantly.
Available vehicle model can be found at:
Stiff Ring - Available Model
Contact us at:
Facebook:Dworks Garage - Automotive - Seri Kembangan | Facebook
Eddie 012-3300 279
Honda Civic EG / DC / EK
