Wts Satria 1.8 MIVEC TURBO
v2peter
Wts: Satria 1.8 MIVEC TURBO (Sunroof)
Satria 1.6 Convert to 1.8 MIVEC TURBO JPJ Approved.
Engine modification:
-engine-full balance
-evo 3 LSD fulllock gearbox.
-turbine standard td05 evo3
-exedy racing clutch
-HKS ori sqv
-HKS air filter
-Mivec ngk power plug cable
-evo3 510cc injector
-evo3 60mm throttle body
-81.5mm piston
-Evo6 intercooler
-full stainless steel intercooler piping
-ACL bearing
-1.8mm metal gasket
-WALBRO 255L/H Fuel Pump
interior:
-Lancer 9rpm 240km/h EL meter
-apexi rsm control Mivec
-evo2 2468 ecu with complete wiring,coil,609 airflow.
-Mivec full set doortrim
-Renoma
Steering
Exterior:
-Stainless steel exhaust piping
-5 Zigen 304 max
-Evo 3 twinport discbrake(frt)
-original side skirts from Mivec
-original Mivec sunroof
-J-speed fender bar
-CCustom room bar
-Ultra racing rear bottom bar
-Mines front & rear upper bar
RM 22k
for more info pls call 012-244 4943
serious buyer only
Bro,
nice spec you have there.
I am just wondering whether the Mivec will still be functioning when the ecu now is using evo 2.
hope anyone can help me here because i am planning to BOT my mivec also.
Good luck on your sales.
Mint condition satria with good price!!
i think mivec launch manually, not via ecu signal.. same like using afc neo to activate mivec/vtec.. correct me if i'm wrong..
my opinion, mivec run better without turbo, trust me, if u want to play with boosting just go with evo4g63/67.. just wasting all money on mivec turbo.. you won't feel enough..
just my 2cent.. sorry if interrupt..
