[WTS] PIAA Automotive Sports Horn for Cars, Bikes and vehicles running 12V
autocrazee
Car horns. Love it or hate it, is undeniably an important part of our vehicle. It has also become part of the soundscape of many large and busy cities. Originally created for safety reasons, its usage has evolved and is used in many other ways these days. The main use of car horns are to caution others on the road of possible dangers.
Such dangers could be:
1. Another drivers lack of attention.
2. When making a turn that has visibility issues due to obstacles.
3. When driving on a road with many pedestrians.
Other uses may include:
1. To let someone know you've arrived without having to politely walk up to the door and knock.
2. To alert the person who double parked behind you.
3. To let the neighborhood know that you're coming for the bride.
4. To get the attention of a pretty lady on the sidewalk.
Agree or disagree on the other uses, you can't deny those are what car horns are often used for these days.
So, if you have ever been in a situation where you needed to use the horns, you know how important it is for it to be loud and attention grabbing, but not so loud that is will damage ones hearing. Ever been in a situation where you pressed the horn but the sound was less than impressive. Asthmatic to an extent. Look at the photo below to understand why.
That is how most factory horns look like. It is no wonder that they sometimes fail to get any attention at all.
Do you REALLY need horns to be loud?
A valid question really. It is without a doubt that car horns are one of the most annoying sounds to most of us. So why would you want a louder horn? Easy. The horn, if not misused is a safety tool. It is supposed to get attention. Having a horn that isn't loud enough is like having a knife that is not sharp. It won't work, and to a degree, would be useless.
Why do manufacturers equip such poor horns?
We don't know, but our guess would be cost. It isn't exactly the first thing you check when buying a car. I doubt most people even think of the horn until after the are driving it home. So its an easy target for cost cutting.
Aftermarket to the rescue (as usual).
Luckily for us, PIAA has some excellent horns that are within regulations, and are able to be installed easily in most cars.
1. PIAA HO-2 Dual Tone Light Weight Twin Super Car Horn 12V (400/500Hz)
Click here for the sound. Please ensure your volume is not set too high!
Sports Horn
Loud horn with a beautiful tone. The HO-2 is perfect to ensure others hear you when it matters, excellent safety aspect. The twin horn produces a wonderful tone with its 400Hz and 500Hz combination. Furthermore, this easy to install horn also comes with weather guard to ensure your horn is kept clear from elements. Made from tough ABS material and rust resistant black chromate, this horn will be of service for a long time. Its light weight and compact design enables it to be installed in most cars.
  • Powerful 112dB Dual Tone.
  • 400Hz and 500Hz combination
  • PIAA Horn can be installed on one and two terminal cars.
  • Black Housing
  • 2 terminal type
  • (Includes ground wiring)
  • Light weight: Approx. 194g/pc
  • Made in Japan
http://www.fasmoto.com/replacement-parts/horn/piaa-ho-02-automotive-slim-sports-horns-400-500hz
2. PIAA HO-8E Dual Tone High Pitch Euro Sports Car Horn 115dB (500/600Hz)
Euro Sports Horn
If the "luxury car" horn tone is what you're after, the HO-8E is perfect for you. Always featuring the PIAA loudness, this horn proves to be the buyer favorite everytime. The higher pitch 500Hz and 600Hz dual tone combination simply sounds perfect. Light weight and compact, this horn can be installed to most cars easily. On top of that, it comes with a weather resistant cover to keep your horn free from contaminants.
  • Powerful 115dB Dual Tone.
  • 500Hz and 600Hz combination
  • Black Housing
  • 2 terminal type
  • Made in Japan
http://www.fasmoto.com/replacement-parts/horn/piaa-ho-8e-euro-sports-horn-500-600hz
3. PIAA HO-9 Dual Deep Tone Superior Bass Car Horn 112dB 12V (330/400Hz)
Superior Bass Horn
The depth of sound of this new “330 Hz” horn far exceeds the popular “PIAA Sports Horn.” The 330Hz combines the dignified depth of sound that swept the world with the tone and quality of a 400Hz horn, achieving a refined serene sound with plenty of depth!!
  • 330Hz and 400Hz combination
  • Black Housing
  • 2 terminal type
  • Light weight: Approx. 187g/pc
  • Made in Japan
http://www.fasmoto.com/replacement-parts/horn/piaa-ho-9-superior-bass-horn-330-400hz
4. PIAA HO-12 Dual Tone Slender Ultra Light Twin Horns 12V (400/500Hz)
Slender Horn
The “Slender Horn” represents a lightweight horn that is the world’s thinnest spiral horn. It is a new horn with the world’s thinnest body in the popular “400Hz / 500Hz” bass range. Big sound in s small package. The HO-12 is ideal for tight space applications. The twin horn produces a wonderful tone with its 400Hz and 500Hz combination. Do not underestimate this horn given its slim build. It will blow you away. Equipped with a stylish guard fin that prevents water and dust permeation.
  • ECE Regulation No. 28 approval
  • Black Housing
  • 2 terminal type
  • Light weight: Approx. 180g/pc
  • Made in Japan
http://www.fasmoto.com/replacement-parts/horn/piaa-ho-12-automotive-slim-sports-horns-400-500hz
