--> NGK SPARK PLUGS B]
Original & Imported from Japan
Worldwide branded spark plugs, make your vehicle more powerful, fuel economical and stable performace.
NGK Iriway Series Plugs
http://2.bp.blogspot.com/-OuMzoiJhKUw/TZV3677jdMI/AAAAAAAAAA8/TJGK8fUcRE8/s1600/NGK%2BIRIWAY%2B7.jpg
Iriway 7 ~ RM81/pcs
http://3.bp.blogspot.com/-mgZ1HvcI2OQ/TZV7YHQLUAI/AAAAAAAAABs/0c9QsC9nqK0/s1600/NGK%2BIRIWAY%2B8.jpg
Iriway 8 ~ RM81/pcs
http://3.bp.blogspot.com/-mp7bTbcQ7co/TZV7YZIywRI/AAAAAAAAAB0/WGJbEOYnbcI/s1600/NGK%2BIRIWAY%2B9.jpg
Iriway 9 ~ RM81/pcs
IRI SERIES spark plugs offer a colder heat rating for performance engines that deviate from standard specification. Offering outstanding ignition performance, lower discharge voltage and improved acceleration, the IRI SERIES spark plugs were developed with performance vehicles in mind.
Recommended for Tuned / Turbo Engine
NGK Iridium IX Series Plugs
http://3.bp.blogspot.com/-cuTR8TGdbfo/TZV8cm5hhpI/AAAAAAAAAB8/T5x6SuZMqO8/s1600/NGK%2BIRIDIUM.jpg
The Spark Plug
Serious Enthusiasts Rely On
Designed specifically for the performance enthusiast. Iridium IX® offers extreme ignitability, improved throttle response and superior anti fouling
* Fine Iridium tip ensures high durability and a consistently stable spark
* Iridium alloy has extremely high melting point, perfect for today’s high-tech, high-performance engines
* Trivalent Metal Plating - superior anti-corrosion and anti-seizing properties
* Outstanding acceleration, high fuel efficiency and durability
* Ultimate design, technology and performance
Recommend Usage Life : 50,000KM ~ 60,000KM
NGK Laser Platinum Series Plugs
http://2.bp.blogspot.com/-I2up7HCOhsg/TZV9G1B35-I/AAAAAAAAACE/4UeV_At-EMo/s1600/NGK%2BLASER%2BPLATINIUM.jpg
Laser Platinum® spark plugs provide high ignitability and longer service life. Dual platinum surfaces ensure slow wear rate providing stable idle, superior anti fouling, improved fuel efficiency and lower emissions.
* Laser welded Platinum center electrode tip
* Platinum disc welded to backside of ground electrode provides long life
* Trivalent Metal Plating provides superior anti-corrosion and anti-seizing properties
* Faster starts and quicker acceleration
* Better fuel economy and lower emissions
* Best Platinum spark plug available
* Original Equipment Manufacturer approved design
Recommend Usage Life : 30,000KM ~ 40,000KM
NGK G-Power Platinum Series Plugs
http://3.bp.blogspot.com/-SwZsq5B9ZyQ/TZV9hzK4xEI/AAAAAAAAACM/d_hejSQPY6w/s1600/NGK%2BG%2BPOWER.jpg
Improved Fuel Efficiency, Lower Emissions, Quicker Starts.
* Fine platinum tip reduces required voltage
* Extremely durable under high heat
* Best platinum spark plug at an economical cost
** With purchase Iriway Spark Plug / Iridium IX Spark Plug will get Free Shipping Charge **
How to differentiate Original NGK Spark Plugs and Imitation Sparks:
http://1.bp.blogspot.com/-DP3J3cwjk-U/TZWANpNz0GI/AAAAAAAAACk/jP1RV2uv3fY/s1600/photo7.jpg
***Please leave message here for the Spark Plugs part number or just tell me your vehicle model, so that i can check the price for you****
Email : [email protected]
Others Product:
Power Window Switch
Side Mirror
Iriway 7 ~ RM81/pcs
Iriway 8 ~ RM81/pcs
Iriway 9 ~ RM81/pcs
The Spark Plug
Others Product:
Power Window Switch
Side Mirror
