WTS Massive Audio Mono Amp. Ultra small size!
ICE -In Car Entertainment
jittyz
WTS RUGI SALE! Just want to get rid of it! Massive Audio Mono Amp. Ultra small size!
Item(s): Massive Audio D1200 Mono
RMS 250W @ 4ohms
RMS 450W @ 2 ohms
RMS 600W @ 1ohms
Very small amp.
Dimensions 7.7" x 6.5" x 2.1" Inches
Logo will lit up!
Volts N' Bolts
Don't be fooled by their cosmopolitan looks. The Digital Block Series Amplifiers provide Massive amounts of Power in a stylish and surprisingly small heat sink.
These CEA 2006 Certified amplifiers boast advanced Digital Power Supply Switching, Bridgeable RCA Connections, Matched MOSFET “N” Drive outputs with an advanced Six Way Protection.
Other features include: Nickel Plated Connectors / 24 dB Low Pass Crossovers with an adjustable range of 40Hz - 220Hz / Adjustable Low Pass 18dB Sub Harmonic Filter with a range of 10Hz - 50Hz.
All of these features are mounted in a beautiful brushed aluminum “finless” heat sink with a ¼” milled top plate bolted down with “hex bolts”.
The four cornered hex bolts unscrew to reveal mounting tubes (see attached pictures) that allows the installer to bolt down the amp for a razor clean installation.
Top it off with a soft blue center logo glow with hundreds of “micro” LEDs. The New 2010 Massive Audio “D” Block Series combines “Style, Form, Function and Performance”
Package includes: Massive Audio amp, allenkey, box, screws. Warranty Card
Price: 800
Warranty: 1 year by manufacturer.
Dealing method: COD. Poslaju included.
Location of seller: Kuching, COD. Poslaju included.
Contact method/details: 012-8898890, [email protected], pm
Age of item: New
Item(s) conditions: New
Picture: http://s.lowyat.net/uploads//attach-27/post-278827-1306251983.jpg
Reason for sale: Bought extra.
Item(s): Massive Audio N2 Mono
RMS 200W @ 4 ohms
RMS 400W @ 2 ohms
RMS 800W @ 1 ohms
Ultra small amp.
Dimensions 7.2" x 5.5" x 2.1"" Inches
Leading The Way!
Massive Audio is now the leader in “Micro Circuit Topology” by fusing micro technology, intelligent design and precision assembly in creating “Nano Block” series power amplifiers for 2010! These six fully compliant CEA 2006 rated amplifiers are designed to fit into restrictive or limited spaces while still delivering staggering amounts of power! “Nano Block” models have one of the smallest installation foot prints vs. power in today's industry.
All six new “Nano Block” aluminum heat sinks are anodized in a “Raven Black” finish that's only 5.5” wide and 2.1“ tall! You can combine all models by stacking or using inline mounting combinations. Just use one of the several state of the art custom CNC machined mounting accessories, that lets you bolt together any mounting combination that you can imagine.
Everything you would expect in a state of the art power amplifier is here in “Nano Block”. 24 dB Low Pass Crossovers with an adjustable range of 40Hz - 220Hz / Adjustable Low Pass 18dB Sub Harmonic Filter with a range of 10Hz - 50Hz / 0 dB ~ 12 dB bass boost control / Dual sided mill spec PCB’s / Protection circuits for short circuit / Overheating and Low Voltage / Ultra efficient Nano Technology power supplies and endless possible installation scenarios make Nano “The Best Deal on the Block”.
http://www.massiveaudio.com/store/product....&cat=251&page=1
Package includes: Massive Audio amp, allenkey, box, screws. Warranty card
Price: 800
Warranty: 1 year by distributor.
Age of item: New
Picture:
