WTS: High-End Speakers from Rep.Czech
ICE -In Car Entertainment
lmh77
WTS: Speakers made in Czech Republic
Currently i have some few hardly find speakers & tweeters "MADE IN CZECH REPLUBIC" in-stock now
1. 6.5" Mid-Bass (4-ohm)- Paper Spiral Coated Designed with Rubber surround.
Price: RM385 (per pair)
2. Fabric Dome 1" Tweeter (4-ohm)
Price: Sold Out
3. 9" Woofer (8-ohm)- Paper Spiral Coated Designed with Rubber surround.
Price: RM230 per piece
4. 6.5" Double Cone Full Range (4ohm or 8 ohm available).-Paper cone with rubber surround. Most natural & accurate mid-bass. pls refer spec. below;
Price: RM335 per pair
For more detail & spec.
pls refer to;
http://www.gr8tunes.net/phpBB3/viewtopic.php?f=11&t=10182
Contact: 012-9142998
(LIM)
TQ.
Mr Lim, the link is dead
pls refer to;
gr8Tunes.net - Car Audio Forum • View topic - Replubic CZECH MidBass & Tweeter for sale
All theses speakers are 100% made & imported from Eurupean (OEM) manufacturer.
Specification for 6.5" FullRange:
ACOUSTICAL DATA
Rated Musical power: 35 W
Short term maximum power: 75 W
Rated impedance: 4 Ohm
Resonance frequency Fs : 55.000 Hz
Rated frequency range: 60 - 18000 Hz
Sensitivity : 92 dB
TS PARAMETERS
Acquired by MLSSA D-0-10
Effective piston area Sd: 126.700 cm2
DC resistance of voice coil Re: 3.600 Ohm
Mechanical Q factor Qms: 2.640
Electrical Q factor Qes: 0.800
Total Q factor Qts: 0.610
Voice coil inductance Le: 0.3
Equivalent volume Vas: 23.000 l
Moving mass (including air load) Mms: 8.200 g
Suspension compliance Cms: 1022.000 uM/Newton
Force factor Bl: 3.6 Tm
Maximum linear displacement Xmax: 2.8 mm
MECHANICAL DATA
Voice coil carrier material: Aluminium
Voice coil diameter: 25.4 mm
Winding height of voice coil: 6.2 mm
Yoke diameter: 25 mm
Air gap height: 4.5 mm
Magnet external diameter: 72 mm
Magnet internal diameter: 32 mm
Magnet height: 15 mm
Compensating magnet external diameter - mm
Compensating magnet internal diameter - mm
Compensating magnet height - mm
Weight 0.7 kg
This speakers provide outstanding acoustic sound. They sound better than some of the more pricey ones I tested at the specialty stores.
No need hook with power amplifier.
Easy handle by HU.
Excellent fits into door panel.
Audition are welcome.
TQ.
This speaker manufacturer (OEM) to SKODA & AUDI car audio speakers in Europe.
:proud::deal::top:
Currently i have some few hardly find vintage speakers & tweeters 100% "MADE IN CZECH REPLUBIC" in-stock now,
for people who enjoy low-wattage, high-class valve amplification, but it can obviously be connected to any high-quality system,
being valves or solid state.
This extended-range 6.5” driver has numerous applications from high-efficiency 2-way TQWT designs to midrange driver
in high-efficiency 3-way systems supplemented by suitable 10-12 inch bass drivers.
- Cellulose Paper diaphragm with rubber surround
- Up to 18kHz
- High efficiency with balanced frequency response and very good low-mid.
ACOUSTICAL DATA
Sensitivity : 92 dB
TS PARAMETERS
MECHANICAL DATA
Weight 0.7 kg
Easy handle by HU.
Price: RM280 per pair
Contact :
012-9142998 (Lim)
Also post at: Mid-Bass from Czech Rep.[New]
