[WTS] Dastek Unichip Q Genuine
dantei136
Hello There...
I have a Dastek Unichip Q that I bought new from AutoEnginuity and Installed in my Honda Jazz GE8.
Last time I bought this new unit of Dastek Unichip from AutoEnginuity was about RM1800 including installation and tuning.
I've been using it for almost 6 month with only a single tuning which were done on the first installation.
As for now I would like to Sell of this Dastek Unichip Q at Price of RM1K Negotiable.
Installation can be made at any local reputable tuner of your preference.
Price : RM 9XX Nego Til Let Go
Reason : Upgrading Standalone
Suitability : Most Na/Turbo Cars
Tuned by : AutoEnginuity (Subaru Specialist)
Aged : 7 Month
Deal : COD
Contact : 016-9074285
Features :
*Fits piggy-back style to existing electronic fuel injection systems & puts engine control back into the hands of the tuner .Renders an otherwise untuneable Engine Management System , tuneable to the extent of what Standalone systems provide & even beyond that.
*No opening of ECU's or burning of chips.
*Supports just about every modern crank style . Updateable firmware means that as new crank styles are released by manufacturers the Unichip is easily upgraded to stay in touch with technology
*The Unichip has 5 map sets available . Every chip can therefore be tuned with up to 5 completely different maps . Maps can be as diverse as a Valet map , then a mild performance map for low octane fuel , then a wild performance map with maximum boost & water/methanol injection , then an immobilizer map.
*Switching between maps is accomplished in 3 different ways : easiest & simplest way is via a 5-way switch (available from Unichip) which can be installed inside the car . Then there's a Bluetooth switch (available from Unichip) which communicates with most modern cellphones . Our most popular map switching method is via our Flux Power display .
*Manipulate 3(Unichip Q) to 5(Unichip Q+) 0-5volt inputs.
*Drive extra fuel injectors
*Drive water injection
*Drive water/methanol injection
*Activate water mist spray for intercoolers
*Manipulate intake manifold flaps
*Manipulate variable cam-timing
*Manipulate timing advance & retard (this is what the other guys wish they could do). REAL-TIME TUNING MEANS A TUNER CAN MAKE CHANGES TO TIMING & FUELING SETTINGS WHILE RUNNING A CAR ON A DYNO & OBSERVE THE RESULTS!!!
*Manipulate air-to-fuel ratio mixtures
*Manipulate oxygen sensor voltages
*Manipulate drive-by-wire throttles
*Activate radiator fan
*Control Nitrous injection
*Control turbo boost
*Control a shift light
*Install & manipulate launch control
*Datalogging feature
*Fit Flux Power Display easily when installing a Unichip hardwire style to a car's ECU or to a car's ECU via one of our blanklooms or via a Unichip Plug 'n Play kit .
*The Unichip is a very cost effective alternative to just about any tuning process & a tuner can often retail a Unichip installation & custom tune at the same price of just the purchase price of even the cheapest Standalone systems.
*The extreme flexibility of the Unichip makes it a perfect choice of Aftermarket performance part manufacturers : an instant tuning solution means speed to market! The Unichip has been used in countless Aftermarket kits as a cost effective , dependable tuning tool.
*Unichip Tuners have access to our website log in section which contains up-to-date Unichip training materials . We also provide ECU wiring schematics for popular early & late model vehicles which enable Tuners to easily hardwire the Unichip to just about any vehicle.
*Tuners are also able to purchase Unichips , Unichip software , Unichip Tuning hardware & Blankharnesses via our log in section.
