If its the one with the rings the only difference is that those need to use a crimp ring to connect. the one I am selling allows you to plug it directly into the cap.
Also as the cap has 4 connections in the + side (2 4gaguge and 2 8 gauge) you can use it instead of a distribution block if you have 2 amps.
Nissan’s venerable supercar clean-up agent, otherwise known as the GT-R, will be receiving the mandatory mid-life cycle freshen-up that thankfully doesn’t just stop...
Anyone know of a brand or a type of paint that I can use to spray or paint the interior with? There are some parts in the car that I need to spray 'cause the parts look quite worn out.
