WTS ARK MULTI FUNCTION DISPLAY
The ARK Design Multi Function Dash (MFD) is an all-in-one meter system that monitors 10 vehicle vitals in real-time on its 2.4" display. ARK Design engineers developed the MFD as a simple, clean and functional solution to the clutter using multiple gauges brings to a vehicle's interior.
Monitors:
•Boost/Vacuum (PSI or kPA)
•Water Temperature
•RPM
•Vehicle Speed
•Throtle Position
•Injector Duty Cycle
•O2 A/F Signal
•Secondary Water Temperature*
•Oil Temperature*
•Oil Pressure*
The versatility of the MFD's display is not limited to just what the screen displays, but also how a user prefers the control panel positioned. The MFD has the unique ability where its display can be rotated 180 degrees, so a user can choose to have the controls on the right or left of the screen.
Also ARK Design offers website software updates at no-charge. Simply connect the MFD to a USB cable, and users will be able to download new updates. For more info, goto link.
http://www.arkdesign-us.com/mfd-multi-function-dash
Like new with box & instructions.
Registered unit.
Kindly contact: 017-3638801
Monitors:
•Water Temperature
•RPM
•Vehicle Speed
•Throtle Position
•O2 A/F Signal
•Oil Temperature*
•Oil Pressure*
Registered unit.
