WrX7 Known Member Senior Member Joined Jan 17, 2005 Messages 266 Points 3,018 Feb 25, 2010 #1 Hi, Anyone knows the size (dimension) ID,OD and length of the Water Inlet Hose connected between the water pump toward the block. See attached. Thanks Attachments Water inlet hose.jpg 82.5 KB · Views: 515
wilm3 500 RPM Senior Member Joined Aug 4, 2005 Messages 500 Points 1,528 Location KL Feb 25, 2010 #2 y u need tat? kong changed once for me...mayb can check wif him...
WrX7 Known Member Senior Member Joined Jan 17, 2005 Messages 266 Points 3,018 Feb 25, 2010 #3 Planned to change it to silicon as well, searching for correct sizing.
F FGT 500 RPM Senior Member Joined May 19, 2007 Messages 529 Points 1,528 Feb 25, 2010 #4 WrX7 said: Planned to change it to silicon as well, searching for correct sizing. Click to expand... I think u can loosen it a bit to measure the inner diameter by measuring the inlet part (that thing u attach the hose to).
chinozie Very Young Member... :D Senior Member Joined Jul 5, 2004 Messages 3,429 Points 5,163 Location Damansara Feb 25, 2010 #5 WrX7 - give me a call on Saturday...I'll be at the mech shop...can check for you then...do remind me...
WrX7 Known Member Senior Member Joined Jan 17, 2005 Messages 266 Points 3,018 Feb 25, 2010 #6 Bro Chin, this saturday not free lar. Maybe i be doin the measurement tomorrow. Thanks.
WrX7 Known Member Senior Member Joined Jan 17, 2005 Messages 266 Points 3,018 Feb 27, 2010 #7 Tried fitted the hose on one of the hose outlet on the engine, the measurement of ID:30mm, OD:40mm on the silicon hose should be sufficient. An estimate of 3inches length would be good enough as i couldn't measure it. Chin, think u can help on this?
chinozie Very Young Member... :D Senior Member Joined Jul 5, 2004 Messages 3,429 Points 5,163 Location Damansara Mar 1, 2010 #8 Hi WrX7... I've measure it last saturday...sorry forgot to update you the soonest... the length was 2.5inch...
