Works Engineering Performance Cam Pulley
huakenny
LB Performance
Kota Kinabalu
Hi,
distributing now the Works Engineering Camshaft Pulley for various car model....CHEAPEST IN TOWN!!!
Description :
Each gear is adjustable in 1" increments to a maximum +/- 10". The engraved timing marks are accurate to within 1minute of a degree!
With the simpler design our gears end up being lighter than the stock gears they replace.
The tooth profile matches the OEM spec exactly for each gear made, the outer cog section of the gears is black hard-anodized, to prevent on/wear from the timing belt. it is black hard coat because of the grear contrast it gives against the engraved timing marks.
The 5 bolt locking pattern is plenty secure and use only stainless steel hardware to ensure durability. this design provides a lifetime of worry-free adjustment.
Machining for optimum component fit is critical with adjustable cam gears. any free play between the inner and the outer secftion will cause the hardware to come loose no matter how much is tightened.
the extra care in the machining process guarantees the gears will not come loose when you follow the torque specifications in the instructions.
Horsepower gains can vary widely depending on what has been done to the vehicle and how it is used. gains from 5 to 20 Horsepower can be realized.
Price :
Mitsubishi Evo 4G63 1-8................... RM460
Mitsubishi 4G9x DOHC...................... Rm455
Mitsubishi 4G9x SOHC...................... RM248
Proton 4G13/15.............................. RM248
Campro gen2/Neo............................RM458
Honda B Series.............................. RM460
honda K Series ............................. Rm460
Honda H Series ............................. RM460
Toyota 4A-.Ge.............................. Rm460
Kancil L2S turbo ............................RM248
Toyota caldina ..............................Rm460
Toyota 3S ....................................RM460
Nissan SR20Det............................. Rm460
Nissan RB20/25/26......................... Rm450
Perdana V6 6A10/12....................... RM900
"These prices only for online member"
All items sent directly via Gdex Express, strictly no COD.
Postage fee is F.O.C and official receipt is given.
Contact:
1. PM
2.Email [email protected]
3. Sms/call 0168417327
