Works Engineering Brake Kit Mitsubishi Lancer GT
Works
www.worksengineering.co
Petaling Jaya
Works Engineering 4 Pot Brake Kit
~ Mitsubishi Lancer GT '07-On (330mm)​
http://www.zerotohundred.com/newforums/picture.php?albumid=2840&pictureid=11087​
- Plug and play
- installation can be provided
- FREE Works Engineering Limited T-shirt (while stock last)
- FREE Works Engineering Sticker
- 1 year warranty
PACKAGE INCLUDE :
- 4 piston calipers
Material : 356 casted aluminum alloy with 4 layers of nanometer-resembled and anti-high temperature special coating.
Application for disk range : 286/302/330mm
Dimension of piston : 40mm/36mm
Application for types : high performance cars
Color : Red
- Brake Pad
Material : Composite ceramic ,carbon fiber
Application : High speed and aggressive driving
* working temperature 50'C -650'C
- Mount Adaptor
High Temperature electro-plated surface treatment and it can resits acid.Also,the product is durable enough to sustain the frequency vibration of braking
- Rotor :
Material : Made of Nickel alloy FC-28 casted iron to provide a better rigidity and hardness than other FC-28 casted iron,working temperature allows to 900'C
Feature : Special designed in an aggressive and daily purpose,due to its components of material,multiple alloys are applied during manufacturing in order to provide excellent braking performance and high stability.Furthermore the rotor surface had conducted in special heat treatment, giving itself a superior corrosion resisting.New cutting design on its surface reduces noise effectively.
RM 3849
Buy it now @ 4 Pot Brake Kit Mitsubishi Lancer GT '07 - On (330mm)
Call us now for more detail
016-229 9610 (whatsapp/wechat)
