Works Engineering Adjustable Cam Gear - CAMPRO
navydagreat
attachment.php
WORKS Adjustable Cam Gears allow fine tuning of the camshaft timing to maximize engine performance and tailor power characteristics for various driving conditions.
Either with OEM or WORKS Camshafts, adjustments can be made to tune an engine’s power band to the optimum RPM range for a particular application. WORKS Cam Gears are made completely of anodized Duralumin with nickel plated gear teeth except for applications with timing chains which utilize an aluminum slide with steel teeth.
WORKS engineers chose Duralumin as the core material for WORKS Cam Gears because its lightweight properties decrease drag on the engine. Precise valve timing can be adjusted and set within the range of ± 20° along a Vernier scale of 2° intervals. Each interval index is laser-etched into the Duralumin and "A" (advance) and "R" (retard) directional markers are also laser-etched on to the cam gear face.
- Material: T-7 Aluminum Billet
- Fine tune your engine power band
- Improve engine performance 15% - 35%
- Improve fuel consumption 10% - 25%
- Lightest Cam Gear in the Market
- Weight: Average 335 Gram (Each)
attachment.php
For Campro Engines (Proton Campro / Gen2 / Satria Neo / Persona / New Saga)
Price is RM 220 per piece.
CALL OR SMS 012-9106 308.
For other car models, please contact to enquire.
Dealing method:
- COD (Cash on Delivery) at Ampang, Ulu Kelang, Wangsa Maju, Gombak and general Klang Valley area.
- Poslaju (Peninsular Malaysia & Sabah, Sarawak, Labuan & Brunei) Poslaju charges may apply.
attachment.php
UPDATE:
Here is a brief explanation on how Adjustable Cam Gears can benefit your car:
[youtube]-LebR_Vw-qw[/youtube]
