- Joined
- Apr 11, 2006
- Messages
- 203
- Points
- 5,016
need sum advice.
all the wirings i do myself...
my stetup:
alpine 9846e
- 1 preout RCA (front/sub selection)
- 4ch speaker level/high output
speaker:
blaupunkt velocity 60w rms
jvc bandpass jvc box
amps:
4ch : kenwood kac 748 - to drive speakerz
- 4ch rca input
- 4ch speaker level input
- 2ch rca lineout
- highpass / lowpass / direct controls
2ch/ bridgeable kenwood PS-100 - to drive the sub
- 2ch input
- stero / mono switch
since alpine players have this funtion to turn off the built in amp inside the player in order to improve sound quality....
but this particular player... when turn off the built in amp, it turns off the 4ch speaker level output (stated in manual n i hv tested).
turn of the built in amp got big diff in sound quality is it??
setup 1 : turn off Built in amp insde player
in this case.... i can only use the 1 preout rca (front mode)... n then use Y splitter for front n rear and use the line out of the kac-748 to drive the sub's amp.
in this setup... do i hv the built in player frequency contorls?
OR
setup 2 : turn on built in amp inside player
connect the 4ch speker level output from player to the speker level input of the kac-748 to drive the speakers. use the 1 RCA preout (sub mode) from the player to directly the sub amp (ps-100) to drive the sub.
loudness setting in player turn off for both setups?
so... which setup to use??
my stetup:
alpine 9846e
speaker:
amps:
- 4ch rca input
- 2ch rca lineout
- 2ch input
OR
