Wide body top up... Where to get it?
apek beca
I got set of 18" rims & very soon I'll be installing a BBK that needes about 7-8mm spacer.
With the rims I've been messing up my car & once I got into wet roads my car would have black dirt lines.
I guess that I've got to spend more money on my car... This seems endless. Still okay for me at the moment.
Next thing that I need to do is to widen my body. Thinking of something simple, maybe about 10-15mm.
Not too wide la... Making it enough to cover & still looks ori. No big chunk pls...
Know of a place that can do this? Something that's welded or bolted on, not double sided tapes only.
Don't want that thing to boomerang killing a something :rofl:
Something as the pix below:
Another thing concerns is the Candy White problem. Some shop can't get the color to match.
Base color problem... blah blah blah... :banghead:
Around how much to cough out for this?
Pls recommend a good shop that can do this...
Thanking all in advance
O... could functions something like wide body right?
Block dirt from spraying to body?
If can the function is still there.
Function are more important than looks :D
bro, wide body is NOT wide wheel arches....different thing.
Wide Wheel arches are found normally found in 4x4. Wide body involved fatter fender and rear quarter panel.
thanks... spending money on this might not be such a good idea.
saves up on lug nut + spacer + could get better rims
going for 50 offset, now on 40
