Wheels went inside abit
simplythebest
1,500 RPM
Selangor
Hi all,
I don't know how to explain this but I feel that my 4 wheels like went in abit .. that makes my car look abit weird .. the other day I park my car at somewhere beside there is a Wira .. I check his wheels and mine his of course look better and fierce .. because his wheels fit perfectly .. why is this? Different absorbers & springs combination different result? I also saw some satrias same as mine. I never done before any screw setting becos my front don't come with the screw.
can somebody tell me what is this screw called? forgotten liao :lol:
If I don't do this screw settings will affect my tires right? like running out of shape?
or not only this .. I must do screw settings/alignment/balancing always to keep the tires in good shape? :unsure:
Thanks :D , sorry for too many questions at once but since this topic got to do with wheels so I just add all of them together.
Brother............not ur wheel go inside lah...... :lol: what size of rim u r using?? 13" or 14"? It's bcoz ur wheel offset is small. The car u saw, which looked fierce must had a larger rims than urs, 15", 16" .........?
larger rim = larger offset = better look.
If u want better look without spending big bucks....use wheel spacer.
dun use too big spacer...later get stuck on the body ahhaha....n tat screw is adjustable camber screw if not mistaken
