Vehicle Inspection Service
cyclonite
Hey guys, Just wondering anyone from ZTH made use of this service before? It looks good, especially the Complete Vehicle Inspection.
http://www.aam.org.my/services_vehicle.htm
[font=Verdana, Arial, Helvetica, sans-serif]Hm...i wouldn;t pay rm100 for such service...[/font]
if you keep your car maintainance in order..you'll know which is whihc and what is what...
btw,they privide these....
[font=Verdana, Arial, Helvetica, sans-serif][/font]
[font=Verdana, Arial, Helvetica, sans-serif]The AAM Vehicle Inspection service is one of the most comprehensive available in the market. If these details are not convincing enough, we don’t know what else could be:[/font]​
[font=Verdana, Arial, Helvetica, sans-serif]Multi-point checks[/font]
    • [font=Verdana, Arial, Helvetica, sans-serif]Engine oil level, leaks, oil condition and mounting[/font]
    • [font=Verdana, Arial, Helvetica, sans-serif]Cranking system[/font]
    • [font=Verdana, Arial, Helvetica, sans-serif]Charging system[/font]
    • [font=Verdana, Arial, Helvetica, sans-serif]Ignition system[/font]
    • [font=Verdana, Arial, Helvetica, sans-serif]Drive belts condition and tension[/font]
    • [font=Verdana, Arial, Helvetica, sans-serif]Fuel filter condition[/font]
    • [font=Verdana, Arial, Helvetica, sans-serif]Cooling system fluid level, leaks and fluid condition[/font]
    • [font=Verdana, Arial, Helvetica, sans-serif]Condition of radiator, hose and caps[/font]
    • [font=Verdana, Arial, Helvetica, sans-serif]Battery fluid level, condition and mounting[/font]
    • [font=Verdana, Arial, Helvetica, sans-serif]Battery terminals and cables condition[/font]
    • [font=Verdana, Arial, Helvetica, sans-serif]Brake or clutch fluid level, leaks and fluid condition[/font]
    • [font=Verdana, Arial, Helvetica, sans-serif]Air cleaner condition[/font]
    • [font=Verdana, Arial, Helvetica, sans-serif]Ignition system components[/font]
    • [font=Verdana, Arial, Helvetica, sans-serif]Air conditioning fluid level[/font]
    • [font=Verdana, Arial, Helvetica, sans-serif]Windscreen washer fluid level[/font]
    • [font=Verdana, Arial, Helvetica, sans-serif]Windscreen wiper condition and function[/font]
    • [font=Verdana, Arial, Helvetica, sans-serif]Lighting system function[/font]
    • [font=Verdana, Arial, Helvetica, sans-serif]Trunk lid function and sealing[/font]
    • [font=Verdana, Arial, Helvetica, sans-serif]Doors function and sealing[/font]
    • [font=Verdana, Arial, Helvetica, sans-serif]Windows function and sealing[/font]
    • [font=Verdana, Arial, Helvetica, sans-serif]Tires inflation pressure and condition[/font]
    • [font=Verdana, Arial, Helvetica, sans-serif]Fuel lines condition[/font]
    • [font=Verdana, Arial, Helvetica, sans-serif]Brake lines condition[/font]
    • [font=Verdana, Arial, Helvetica, sans-serif]Hand brake linkage and cable condition[/font]
    • [font=Verdana, Arial, Helvetica, sans-serif]Exhaust system condition[/font]
    • [font=Verdana, Arial, Helvetica, sans-serif]Shock absorbers leaks[/font]
    • [font=Verdana, Arial, Helvetica, sans-serif]Steering linkage condition[/font]
    • [font=Verdana, Arial, Helvetica, sans-serif]Propeller shaft and universal joint condition[/font]
    • [font=Verdana, Arial, Helvetica, sans-serif]Transmission leaks, oil level and oil condition[/font]
    • [font=Verdana, Arial, Helvetica, sans-serif]Rear axle leaks, oil level and oil condition[/font]
    • [font=Verdana, Arial, Helvetica, sans-serif]Undercarriage general condition[/font]
[font=Verdana, Arial, Helvetica, sans-serif]Road Test Check Points[/font]
    • [font=Verdana, Arial, Helvetica, sans-serif]Engine starting characteristics and acceleration[/font]
    • [font=Verdana, Arial, Helvetica, sans-serif]Clutch clearance and function[/font]
    • [font=Verdana, Arial, Helvetica, sans-serif]Hand brake function and adjustment[/font]
    • [font=Verdana, Arial, Helvetica, sans-serif]Foot brake function[/font]
    • [font=Verdana, Arial, Helvetica, sans-serif]Transmission gearshift function[/font]
    • [font=Verdana, Arial, Helvetica, sans-serif]Drive shaft function[/font]
    • [font=Verdana, Arial, Helvetica, sans-serif]Steering operation, center position, free play and straight position[/font]
    • [font=Verdana, Arial, Helvetica, sans-serif]Dashboard panel gauges function[/font]
    • [font=Verdana, Arial, Helvetica, sans-serif]Safety belts function [/font]
[font=Verdana, Arial, Helvetica, sans-serif]Exhaust Gas Analysis[/font]
[font=Verdana, Arial, Helvetica, sans-serif]Measures the relative volume of certain gaseous constituents in the exhaust gases of motor vehicles with spark ignition. These gases include carbon monoxide, carbon dioxide, hydrocarbons, oxygen, and oxides of nitrogen.
Vehicle Electronic Systems Diagnosis
1. Engine Management System (EMS)
Data stream - checks the EMS sensor signals, components readiness and output stage information from the EMS electronic control unit (ECU).
Read fault code - reads fault codes, known as Diagnostic Trouble
Codes (DTC), direct from the EMS electronic control unit’s memory.
Activation test - activation of the solenoid components accessible to the control unit. This will check if the component is functional and the quality of its operation.
2. Anti-lock Brake System (ABS)
Data Stream - checks the ABS sensor signals, components readiness and output stage information from the ABS elesctronic control unit (ECU).
Read fault code - DTC direct from the ABS electronic control unit’s memory.
3. Supplemental Restrain System (SRS)
Data Stream - checks the SRS sensor signals, components readiness
and output stage information from the SRS electronic control unit (ECU).
Read fault code - DTC from the SRS electronic control unit’s memory.
4. Electronic Transmission Control System (ETC)
Data Stream - checks the ETC sensor signals, components readiness, and output stage information from the electronic control unit (ECU).
Read fault code - DTC direct from the ETC electronic control unit’s memory.
[/font]
correct alantan, as a car owner, must know basic procedures in maintainig car rather than giving to other people.
Few point as basic, when do audio system wirings, dont hand-over to dumb peoples to do it, i personally hate it when under-experienced teenagers in those accessories shop touch my car. Thats the 1st point we lose our cars wiring system. Cutting there and cutting here, improper sorted wires due to save cost.. uish! terrible. Please consult more professional service rather than being D.I.Y on certain serious areas in car.
As a car owner, he must knows .. change engine oil, change plugs, replace brake fluids, radiaotor cleaning, battery fluid maintenance, brake check-ups, belting check-ups .. and i know most drivers dont know proper tyre change when inflatted ;) .. he he those said things are very basic and we can spend once every 2 or 3 months for our car ... agreed?
Well, we could use that list and do the check ourselves, at least for those that we can do by ourselves. hehehe
I was asking one of my friend about this service. He told me he was the one who started it up at AAM when he was working there many years ago, he said at that time they were very good but right now not sure. Also, during his time cars were not so electronic yet.
No need la... all these i can ask my mech check for me free also.
Some of the listed above can DIY also.
Pay RM100? I pump petrol better...
Actually, I don't mind paying RM100, maybe twice a year, if they REALLY know how to do those stuff. But in Malaysia, fuck them stupid ass fuckwits. Out just to slash people's wallet.
AAM is independent. The government appointed them to help the public in all areas of car related matters so this is just one of their offerings to the public. They are government sponsored, not out to cheat your money la.
