hmmm since bro normality78 post about valve shim. so i tumpang thread wanna ask. may i know what is the difference between valve reshim and under bucket shim (or something like that)? - not very sure.
btw, replacing shims need to do some calculation, coz of wear n tear.
like mine, after replacing some valve, got sounds like "tepet".
mech said quite hard to replace coz need special tools.
the tools function to press the valve down and "cungkil" out the old shims, and then replaced with new shims.
b4 that, between shims n camshaft clearance/gap need to calculate before getting replacement shims, as shims come in variety of thickness.
Can anybody tell me where the speed signal to the ECU comes from on a Mitsubishi FTO 6A12 (MIVEC and non-MIVEC) - is it off the crank, or off the distributor?
