Urgently looking for AE111(Supercharger) Drive Shaft ! ! !
Hello Mate..
i'm looking for the AE111(Supercharger) driveshaft for Toyota corolla seg or maybe u guys have any other options to replace the current shafts which are almost worn out. been searching at many of the chop-shops but they said it's kinda difficult to find as the shafts always come together with the half-cut. So really need help form u guys to solve this problem. PM me if u have/know where to find the shafts ok. Ur help much appreciated. Thanks. :regular_smile:
do you mean AE101 Supercharger? coz AE111 only have 5speed & 6speed BT...
the other option is that you can recond your driveshaft, many of sc owner here
know the best place to recond their driveshaft...
trueno101>
think so,maybe ae101, sorry don't know much about this engine. thank you very much for the info.
So any sc owners here would like to lend their hands & help me here whether to get the replacement or to recond the shafts as suggested by trueno101
actually i bought de sc engine also came from Ae111 trueno halfcut, so weird.. i asked chopshop boss he said ae111 trueno got sc version also... last year me just repair my driveshaft 3 times, damn many problem
The trueno sure got supercharger, but if u try to find the whole " BATANG " of the drive shaft u need to find gze type to fit into ur gb. if only find the svt or bt it won't fit at all, cos gze drive shaft the gear part into gb is big size. good luck to u...... u lowered ur car too much cause the driver shaft kong very fast.......i also facing this problems three years ago.
i think tom's@alvin got the drive shaft..
try to deal with him if its still available
i think the sc drive shaft from AE92 model also same right? i got 1set, but the thing at ipoh now, if u interested to have it u can call me at 012-5713315 or 0165952221.:_:
There are differents between LSD and non LSD models for 4azge driveshafts! If you are using a ae101 supercharger, then your gearbox will be a LSD gearbox type! You will need to use driveshafts from AE92 or AE101 LSD gearbox.
My recommendation is that you should shift back to use the stock c50,c52 or the c56 gearbox, since the supercharger driveshaft are so expensive! Supercharger gearbox and drive shaft weight about 30KG more than the normal gearbox and driveshaft!
You will just need a strong clutch cover to hold torque!
yup i hav 1 pair taken out from my car.....left n right....lsd gearbox.....gearbox n engine for sale also...call me at 012-2249991
c50/c52/c56 from ae???
my fren already changed his sc gearbox to st gearbox because of this problem...
