Tyre choices.
For those wondering the thread pattern on RE01Rs, here are pics. As you can see, I really work these tires out when the coast is clear (e.g. downhill, where you can see if there's roadblock or oncoming traffic and the entire stretch of road is viewable.. testing mah! I drive like grandmother on tranquilizers when there's traffic. ROFL!)
Be warned.. these tires are wide if you run 16", and if you run B16s, the car has not enough power to push them (I'm using B16 now) if you shift too early at 2nd gear/3rd gear. Jumps like a bucking broncho, yo!
So far, I've only dared go up to 160kmh on 70degree turns, and haven't gotten the rear end to slip.. I could go higher, but the rear end rolls too much it's scary.
And yes, 16" wheels with these tires WILL rub at full lock, so 3 point turns usually become 4-5 point turns, unless you fancy replacing fender liners every so often.
Eh, what about Azenis RT215? It's semi slick oso rite? Anyone here can review 'em? What's the current RMs for a set of 205 / 15 / 50? But u can only rotate, i.e front right to rear right, and not criss - cross pattern eh?
preparing for the next track day i see....hehehe...2 words for u..."bulk purchase"...heheh...
Chibai, here I oso kena wan...No lah, my tyres still very good. Can last until the end of this year, just checking the prices, if it's ok, can budget lah. Wei, join in the club's 2 Fast 2 Shitless group 'tonton' lah. oledi updated the thread in the club's forum!
thanks to pirated vcd & dvd, i can't even remember when last time i go watch movie ler...:_:
hattech-v said:
udeng, next track day this sunday rite?
i'm going...
really?...not HCOC one i guess....open track kot...i can't go, still running in...bside, hafta pack also cause going to sinkapoh the next day...
otw to sinkapoh can singgah wat...
finish ur running in inside there laa... kekekkeke
u can try asking stamford tyres of glenmarie, shah alam about the RT215s. do ask them if they have already have the latest RT615s.
udeng,
u got new pistons meh? run in of what?
ace,
forget abt rt215. go for r888.
399 said:
udeng,
ace,
399,
no lah...wher got money for piston...just new tyres onli...tyre shop said kenot drive fast must run in first drive below 4k rpm...
hahahahaa...udeng, feel a lot more torquer with those new rubbers eh ?
aiseh...u've made a big mistake there......not break in properly the rubber means loss compression ler.....ahahahahaa....
that's why lar....must run in properly...shift gear below 4k rpm...keep below 110km/h...after run in then can onli do dyno...:mouth_closed:
udeng,
so.......did that shopkeeper tell u to run in for how long? what's the diff between run in & not?
first time I hear this.. usually people just warm up their tires before drag race.
