Twin Pot Replacement Disc Rotor, 4 x 114.3 PCD
drexchan
2,000 RPM
Bukit Jalil
IMPORTANT REMINDER: Read this post thoroughly before you ask. When you are calling/SMS, kindly introduce yourself (name, forum, car model).
http://userland.fotopic.net/logos/358416.gif
TWIN POT ROTORS, 4 x 114.3, 283mm diameter
Searching up and down for a reliable replacement for your twin pot disc rotor? When new units from mitsubishi is too expensive, and half-cut parts are getting rare, are you driving with your dangerously worn-out rotors? Get them changed now with our replacement rotors! No drilling (5-lug to 4-lug) required, plug & play*.
*minor modification on your caliper bracket required.
RM450/pair
http://images.fotopic.net/1yz70a.jpg
PRODUCT RANGE: Gen.2/Persona/Waja/Wira, etc with EVO twin pot, using 4 x 114.3 PCD.
MODIFICATION & INSTALLATION: Provided FOC
WARRANTY: 1 month (usually there's no warranty for wear & tear items)
CALL: 019-359 3909 (Drex)
http://images.fotopic.net/y0ikzm.jpg
bro, may i know the center hole diameter, thinkness and height? thanks.
If you plan to use a Twin pot on your Gen.2, you need to transplant these parts from the EVO GSR: - calipers, hoses, rotors, knuckles, front lower arms.
This rotor that we are selling is for those who have made the transplant, and now looking for replacement rotors, which means, it's not plug & play to original Gen.2 braking system.
hi,
no i am not using standard braking system... i am using grippen 4 pot. need to find new disk so that i can mod my bracket... huhuhu~ need to know the exact size to tell whether it is still can mod or have to make new bracket... huhuh~
thanks for visiting today. I will contact you once the new rotors have arrived. :)
http://www.zerotohundred.com/newforums/search.php?do=finduser&u=6936&starteronly=1
Hi Drex,
Loving the new rotors so far :)
any news on the brake pads?
bro can pm me price for rotor only for myvi thanks
hi, wat modification does it require? i mean for the caliper bracket?
dun really understand... hehe
using this more than 4 months already.. no issue at all... nice replacement.. bump for u drex
