TURBOSMART Comp-Gate 40
powerautohauz
((( God Level 30,000 RPM )))
TURBOSMART COMP-GATE 40mm
DESCRIPTION:
Turbosmart’s brand new 40mm external wastegate was designed to fit into tight engine bays while still offering superior flow and heat handling capabilities. The revolutionary new actuator housing is 25% smaller than our current range and allows for easy spring changes and gives the ability to index the cap orientation in 12 different positions.
APPLICATION:
Suitable for all turbocharged vehicles with an external wastegate turbo system. Street and racing applications. Flanges suit 1.75” outside diameter pipe.
SUPPLIED WITH:
7PSI Spring (installed), Inlet and outlet Weld Flanges, Inlet and outlet V-Band clamps, Valve seat, 2 x 1/16th blanking plugs, 2 x 1/16th Vacuum nipples, Locking Ring removal tool. Kit Builder Packs available to customer specifications.
Bakuso Racing Sdn. Bhd.
No.21, Jln PJS 11/24,
Bdr Sunway.
47500 Subang Jaya.
Land Mark:
Desmond 017-396 8567
Email us : [email protected]
