Originally posted by Battousai@Apr 13 2005, 13:53
Probably, yeah. Low boost on a big turbo is different from low boost on a small turbo. Just be very careful not to run lean as the VF8 is significantly larger than ur stock B6 turbo. But since u'll also get more lag, there's really no point in running a low boost big turbo.
[snapback]893287[/snapback]
Originally posted by pimpin323@Apr 17 2005, 23:48
uuuuh thanks man for the tips! i'm looking for something around that figure 200hp. will look for the rb20/25. mmg wanna one shot do banana extractor and downpipe and upgrade bb turbo wid management. zooom zoooooooooooom zooooooooooooooooooooooooooooooooooom!
[snapback]905580[/snapback]
>> Sound too familiarrrr https://www.zerotohundred.com/forums/style_emoticons/default/ph34r.gif alt='ph34r.gif' /> .......
If u're looking for around 200hp on wheel, then VF10 is good enuf for B6T.
running at 1.2bar with proper exhaust system/external wastegate, racing clutch, u shud be able to get around 200-215hp on wheel.
VJ20 in a B6T shud get u around 175-190hp running at 1 - 1.1 bar.
bear in mind, B6T + VJ20 running at 0.9 bar with no additional injector is way too lean.. AFR reading is around 12.5 - 13 be very careful about that.
[snapback]916848[/snapback]
Hi... would u mind sharing ur car spec? I wud luv to hear.... takut gak dengar 1.4-1.5 bar nie.... macam a bit tinggi... so kalau u bleh share spec engine then best lar..... u car B6T @ B8T? still standard internal ka?
Originally posted by pimpin323@Apr 24 2005, 00:29
200 cukup bang! kang langgar tembok tak sakit sangat muwahahahahahaaaaa
[snapback]922134[/snapback]
Originally posted by pimpin323@Apr 24 2005, 12:04
nice 323 dood! very clean! love the apexi meter and your ekjoz ganas woooo!
[snapback]922816[/snapback]
