Tufoil and Magnetized Oil Filter
n305er
- Penang -
Just got 1 bottle of Tufoil from Tesco to try it out wonder if it's genuine.
Are Tufoil attracted to magnetic force?
I'm probably going to add a strong magnet on my oil filter and if Tufoil is attracted to magnets, then it'll be wasteful if I do that.
Thanks for your purchase of Tufoil,n305er.
Tufoil is not made of metal and will not be stuck to magnets.
The magnet that you put into the oil filter is a lovely idea. But be careful that this is a permanent magnet from a reputable company with R & D. Otherwise, you may end up with a floating magnet.
Years ago, we tried a strong flux permanent magnetic sump nut from USA.,the nut that you open to release your dirty oil. We did not see or feel any iron filings or debris after 5000km. We had been using Tufoil on our cars for years already. This only means that there was hardly any wear and tear for the moving metal parts in the engine. Cheers!
Before that, I came across this magnetic jacket in USA last year and was quite impressed with the invention.
The magnetic slabs are very strong and the snag is that each time you have to change your oil filter, you will need a very strong hand remove the magnets from sides of the filter. But when you use a hacksaw to cut open the used oil filter, you are going to be shocked to see all the slag or iron filings stuck to the internal walls of the oil filter.The poorer the quality of the lubrication in the engine, the more you are going to see of this slag. Tufoil has the lowest coefficient of friction known to man. Motor oil enhanced with Tufoil drastically cuts down engine wear. You will see little or no slag like the US-made magnetic sump nut we had used.
