- Joined
- Jun 15, 2006
- Messages
- 1,380
- Points
- 1,638
TSD Boron Nitride Thermal Coating
Delevoped in the USA,TSD Boron Nitride Coating is a revolutionary coating that helps to improve heat exchange efficieny.Where TSD coating is applied,it will improve thermal management by reducing internal temp. by 10%-20% effectively.
It can be applied to virtually any surface/material that can benefit from better thermal management or surface protection.
Applying the TSD thermal coating effectively extracts heat from the heat source.The heat is quickly directed away and cooled by temp. differences.
In addition,the thermal coated surface forms a white graphite-like protection layer against oxidation.The increased surface area will effectively allow more air-surface contact for cooling.
The coating process does not require special equipment, dries quickly, can withstnd heat of up to 200 degrees celcius and easy to use.
Car components to apply:
-intercooler
-radiator
-AC condensor
-turbo kit
-engine
-brake caliper
-valve cover
-extractor
-intake manifold
-and many more......
TSD red (up to 200 celcius) : RM299 per bottle
TSD blue (up to 1500 celcius) : RM399 per bottle
Interested may contact:
STEVEN 016-3943182
-intercooler
-radiator
-AC condensor
-turbo kit
-engine
-brake caliper
-valve cover
-extractor
-intake manifold
STEVEN 016-3943182
