is it Silvertop or Blacktop ?
Does it happened during cold start ?
or
did it happened during normal driving and stop at traffic light ?
yup...correct...
better leave as stock as it is...
no all can alter it...only most experience mech can do it...
by the way...have you check if there's any error code...
clean your TB...
reset your ECU again...to refresh it up...
sifu... need your help on something, last time when i use diagnostic machine to check my car, i found out that even with full throttle, the figure only register as 82% and not higher.. i was wondering how can i solve this problem, and if i cant then will it affect the performance of the car. FC or power or idling......
i'm not sifoo...just a normal 20V fan... :D
what do you mean by this :
not quite understand...is it on the diagnosis software telling you that your TB only open 85% or else ?
... the service that they...
