Hi,
I have a Toyota Corolla XE Saloon AE91, 5AFE, 1498 CC car.
And need to replace the distributor.
My car looks like the car in following link, except the automatic transition.
http://www.beforward.jp/toyota/corolla-sedan/bf361570/id/465591/
At the end of the gallery, there is a picture of the engine and you can see the look of its distributor.
OR
It looks like this:
http://www.zerotohundred.com/newforums/picture.php?albumid=3273&pictureid=11273
You can see coil...it has a circular surface.
But most of the distributors I found on the internet have a slightly different look:
http://www.zerotohundred.com/newforums/picture.php?albumid=3273&pictureid=11272
You can see cover over the coil. It has a different but similar shape... but all the others are looks OK.
Now this type of distributors are for 1.6L engines (that is what ebay/aliexpress says) and I believe my one is 1.5L.
In my distributor there are 2 connectors, with 5 pin and 2 pin.
All the others I found on internet have 4 pin connector and 2 pin connector.
If I found a distributor with slightly different look and if it fits, including connectors, If it is OK to use it regardless whether it is 5AFE, 4AFE or 1.5L, 1.6L....etc ?
Appreciate any advice.
I do not have any mechanical knowledge :(
Thanks!
OR
It looks like this:
Thanks!
with me and AE111-SEG joining in the fun..
