TOYO ENGINE OIL,LUBRICANT,GREASE, all about protecting your car (Performance Parts)
MzLube Lubrication
From Facebook
ABOUT THE COMPANY
MZLube Enterprise was incorporated in 2010 and its related subsidaries, market the products manufactured by Toyo Grease Manufacturing (M) Sdn Bhd. The company has delivered grease products to a wide variety of business and also in developing special programs and formulations for customers' unique needs. Toyo Lubrication immediate response to customers' needs which includes trial run, manufacturing, packing and technical support is a success factor in the way we conduct our business. We are selling various types of grease that are used for automative, industrial, agricultural and household applications.
Toyo Lubrication already exported its' products to countries like Bangladesh, China, Hong Kong, Indonesia, Macau, Mauritius, Middle East, Myanmar, Pakistan, taiwan, Singapore, Vietname, United Stated of America, United Kingdom, Italy, France and others at competitive prices.
OUR MISSION
To supplier the high quality grease and lubricant for better lubrication. With high quality grease and lubricant, it would save cost on maintenance.
ABOUT OUR PRODUCTS
Toyo Grease's products are high and premium quality. We supplier a variety of grease from low temperatures to high temperatures.
PRODUCT WE MOST RECOMMANED TO YOUR CAR
URANIUM 9000M PRO TLU-SAE 550 FS
Description
URANIUM 9000M PRO-GOLD is a Premium High Performance and High Speed Advance multi-grade engine oil formulated from high quality premium paraffinic base stocks and special additives package to ensure optimum lubricating performance. It has been fortified with high effective Detergent / Dispersant additive system to Preserve Power Output and Fuel Economy. It also contains Non-Dispersant Olefin Copolymer Viscosity Modifier and Friction Modifier to resist high shear and operational stability.
Advantages / Benefits
Preserve Power Output and Enhance Fuel Consumption Efficiency and Economy.
Excellent Start-up Protection and Rapid Circulation.
Designed to Protect Against High Friction and High Shear.
Smooth and Dependable Performance.
Excellent Anti-Foam and Anti-Rust Properties.
Protects Against Sludge and Oxidation.
Reduces Oil Thickening for Maintenance of Engine Output.
Minimal Oil Consumption.
Extended Oil Drain Interval.
TITANIUM 8000M TLTI-SAE 1540 SS
Description
TITANIUM 8000 L GOLD Series is a Premium High Performance and High Speed Advance multi-grade engine oil formulated using Synthetic Technology. It has been fortified with special additives Booster, a Non-Dispersant Olefin Copolymer Viscosity Modifier and Friction Modified to resist high shear and operation stability. It provides excellent protection under extreme driving conditions and improves engine life. TL-TITANIUM SS Series multi-grade series are specially blended to lubricate diesel and gasoline engines requiring API SL or CF-4 performance.
Boost Power Output and Enhance Fuel Consumption Efficiency and Economy.
FLUSH KING - ENGINE FLUSH
Description
TOYO Flush King is specifically designed to remove gum, sludge, varnish, grease and dirt build-up in a quickly and easily way. Use regularly to restore engine performance, fuel saving and reduce carbon emissions
TOYO Flush King is formulated from unique ingredients to penetrating, loosening and cleaning of deposits. It is fortified with special additives for removing most dirt from all kind of particles. With the new improvement of Flush King, it will help to reduce fuel consumption as well as to gain power from all kind of vehicles. It is easy to apply
Application
TOYO Flush King is recommended for use on all kinds of engine such as turbocharger, carburetors, fuel injectors, inlet-manifold, throttle plate, automatic chokes and PVC valves etc. which can be applied into both diesel and gasoline engines etc.
The lubricating ability of TOYO Flush King were made with special raw materials and additives from USA which will provide a powerful adhesion and strong cushioning action. And which is much suitable for Professional use.
Powerful jet spray aerosol
Clean with minor disassembly
Effective penetration, loosening and cleaning of deposits from all types of turbocharger , inlet-manifold, carburetors, fuel injectors, supercharger and other air intake components etc.
Help to remove gum, varnish , dirt and carbon deposits.
Reduce repairing cost.
Which help to gain engine performance, fuel saving and reduce carbon emissions.
User friendly and environment friendly
PM ME FOR MORE DETAIL OR I WILL PERSONALLY GET TO YOU AND EXPLAIN!
ABOUT THE COMPANY
OUR MISSION
ABOUT OUR PRODUCTS
Description
Description
Description
Application
for more details about our product...please kindly log on to our facebook http://www.facebook.com/home.php?#!/pr...100001714570409 it's a product that you will never regret to use...dont believe??try it
Re: TOYO ENGINE OIL,LUBRICANT,GREASE, all about protecting your car (Performance Part
come test the different....the new era of oil lubricant
