TOMEI Fuel Regulator With Meter
powerautohauz
((( God Level 30,000 RPM )))
TOMEI ADJUSTABLE FUEL PRESSURE REGULATOR
FUEL UPGRADE REQUIREMENT
When the injectors and fuel pump are upgraded to a larger flow setup the stock fuel pressure regulator will not be enough to suit the required pressures for the new setup. Also the stock is already preset to from factory for the standard setup and non adjustable so it will be restricting the tuning potential of the car. The TOMEI Fuel Pressure Regulator will ensure stable pressures are supplied with the oversize diaphragm. This special design has proven to maintain the required pressure levels with any adjustments made.
Bakuso Racing Sdn. Bhd.
No.21, Jln PJS 11/24,
Bdr Sunway.
47500 Subang Jaya.
Land Mark:
Desmond 017-396 8567
Email us : [email protected]
