Tial MV-S 38mm Wastegate
powerautohauz
((( God Level 30,000 RPM )))
TiAL MV-S 38mm Wastegate.
Brand New 100% ORIGINAL.
Available Color: Blue & Purple.
TiAL's line up of high performance, race proven Wastegates. TiALs Wastegates are trusted by the biggest names in the racing industry. With so much depending on the performance of the valve, its no mystery team leaders choose to equip their cars with the best.
Description:
- High temp NiCrFe based alloy is used for valve and 347SS valve housing will offer longer product life compared to competing designs.
- High temperature silicone Nomex reinforced actuator diaphragm.
- 17-7 PH Stainless Steel actuator spring gives consistent pressure at high temperature, resist "relaxing" at temperature to 900F (483C).
- Nitronic 60 Stainless Steel is used for the valve seat, and valve bushing.
- All Stainless Steel hardware.
- Mating weld flanges are 304L
- Color anodized aluminum actuator (Silver, Red, Blue, Purple, Black).
- 3 lower ports and two top ports for easy install, no need to rotate the actuator top at all, plugs included for unused ports.
-Ultra compact design fits in very tight spaces, the unit stands only 3.7" tall, more compact than any other external wastegate on the market today.
- V-Band inlet and outlet make install easy, flanges and clamps are in the box!
- Integrated -4 AN water cooling ports that cycle a small amount of coolant through the actuator top to keep the temperatures down in extreme conditions such as road racing. These are leak tested after installation from the factory and can be removed if not utilized.
Included with every Tial MV-S:
- MV-S Assembly
- 2 TiAL -4 removable water fittings
- MV-S Valve Seat
- Inlet V-band clamp
- Inlet Flange
- Outlet V-Band Clamp
- Outlet Flange
- 2 TiAL Air Fittings
- Plugs for unused air ports
- Extra actuator springs
Bakuso Racing Sdn. Bhd.
No.21, Jln PJS 11/24,
Bdr Sunway.
47500 Subang Jaya.
Land Mark:
Desmond 017-396 8567
Email us : [email protected]
