The other day I installed one simple light connected to the VVT trigger pulse from the ECU. It was quite exciting because after that i get to see how VVT works.
VVT will always switch on whenever the engine is cranked up. And will shut off once the ECU sensed some load on the Throttle Position Sensor, Oil Pressure and Vacuum(?). Yes, initially I tought VVT was RPM activated similair to VTEC or MIVEC, no it's totally the opposite.
Upon hard acceleration, VVT will shut off completely to return the Cam angle (retard) to accomodate High Revving. This is very consistent as whenever I plunged the pedal, VVT will immediately shut off. But it will turn back on instantly when pedal is released. And on cruising (Closed Loop ECU mode) it will always be on regardless of the RPM.
So my conclusion is that VVT is purely designed for optimised fuel delivery while maintaining substantial performance - specially on Closed Loop operation where the ECU will fully revert to Engine Sensors (specially O2 sensor). While in Open Loop Mode (70% or above on Throttle opening) where the ECU tries to match the best setup for performance, VVT will be completely ignored.
VVT - MCSB solutions for uncles hahahahaha
PS: Oh yes, just in case you ask, the other RED light is connected to radiator fan, just to tell me when the fan is turned on. The yellow indicator is for VVT
