- Joined
- Jun 29, 2008
- Messages
- 887
- Points
- 1,518
was trying out my car on drag strip today boosting only at 1.1bar. Found out that there is a leak somewhere near the charger. causing the charger to open only at 0.10 bar. i have to jack up and check where is the leak.
before this, im boosting at 1.3bar. NOTE: for SC14 players, pls change gears at 6.5k, if you want your charger to have a long life. Dont risk by melting it.
Im still using stock IC. Will try to use FMIC from VR4 soon. See if there is any increase in boost and also any lag.
I m thinking of using 7A block. Any idea of how its done? Will it be PnP to Gze? Do i have to change pistons as well?
Any idea on wat mod is to be done to crank shaft to get better performance?:hmmmm:
Wrongly placed my post , kindly refer to the link
