Temperature Issue
Accord80
Seattlewangsa
Driving a Myvi BOT an I have this problem. After driving for some long time (2 hour+++) and stop, the temperature is rising. But, the temp will going down after drive back. Same thing also happen when driving from home to office (around 4-5 days). FYI, the head has been PnP to the max, got alu radiatior and run without thermostat. The fan is in good condition. Went for pressure test, it shows okay. What does it mean? Do I need to install an oil cooler?
y did u remove your thermosthat? its there for a reason.
Ermm....just do it according to my mech. FYI, I'm still new to turbo coz playing NA for a long time. But since this is happened (overheating) I decided to put back and still monitoring. If someone with experience can help me with these...
maybe your fan not powerful enuf...do check it as well....
try to use water wetter...might decrease your water temp abit.
i noticed dat some ppl like to remove their themostat...
n normally their reason is so dat their engine wud always in a low temp condition...
can anyone clarify on this...?
logically n theoretically to me it seems like it can be done...
but juz like bro danzeterna said...
it's there for a reason rite...?
well im not sure bout that but im definately not removing mine, alternatively there are sports thermosthats available though.
well...i suspect the aluminium rads not have enough cooling capacity....
p/s:copper rads better than some aluminium rads
Petrol powered car needs to operate on an optimal operating temperature. Having the thermostat on all the time with the temp lower than usual will cause higher fuel consumption also.
Thermostat valve open at certain temp degree to allows water to flow from engine to radiator........without thermostat mean ur water in cooling system is flowing all the time...that y the temp is low
If ur temp going up when idling(car x moving) and going down when moving....mostly is the fan issue....but not sure,u hv to double check d fan...add one more fan better
You mentioned tempreature will rise, how did you monitor it? External water tempreature meter? Or using your original meter? If external meter, how much is the range.? Have you checked the water level inside the radiator when cold? (Not the reserve tank)
if head warped then when driving temp will rise immediately
Like what Pomen GTR said, Alu rads are not actually as efficient as copper rads. The only advantage alu has over copper is that it doesn't rust and most of the time aftermarket alu rads are made bigger so their surface area is larger. You're better off with a 2/3 layer copper rad imho.
Engine oils run at their optimum viscousity at 100 degrees celsius. So if you take out the thermostat it'll take the oil much longer to reach optimum viscousity and what does that mean? It means your engine is not getting the proper lubrication for a longer period of time. And why is that important? 90% of all engine damage occurs at cold startup. So if it's cold longer, more engine damage. We're not talking catestrophic breakdown here, just faster wear and tear of the piston rings, valves, bearings and generally most metal bits and pieces inside the engine.
In this BOT overheating case - can I ask if you are using oversized pistons? Or did you just plug and play K3VET low comp pistons? I suggest you change your radiator cap as well as the thermostat to an aftermarket thermostat. It sounds like it's not opening early enough to compensate for the larger heat the BOT is causing. Either that or your radiator is not getting enough air. Some Myvi bodykits are very restrictive and what some people do is drill holes in the front chassis bit that's blocking the radiator.
Izso, What happens if one uses oversized piston? What are the consequence and how will it affect the temperature?
What ecu you are using? Certain aftermarket ecu have different setup for fan controller. If that is a prob, try to find an aftermarket fan controller
Nothing's wrong la. Just depends on how much oversized. Cuz the alu block for the K3VE is very thin already so overboring it will make the pistons damn close to the water jacket and that in turn will heat up the water much quicker than usual.
