T.M.Works Direct Power Harness for Toyota Daihatsu Perodua 4 Cylinder Engines
https://youtu.be/ehEgi0HKKX0
The Direct Power Harness by T.M.Works is a kit that allows for a more stable voltage to the ignition coil from the battery.
In most typical OE harness, about 0.6V - 0.8V voltage drop to the ignition coil can occur. In addition, contact resistance due to aging can also be a contributing factor to voltage drop. This drop could lead to a damaged ignition coil, damaged engine or worse case, a fire.
With the T.M.Works Direct Power Harness, the drop in voltage is kept to a minimum of 0.2V at most. For example, if an ignition coil outputs 23,000V with the input of 13.8V ,when a 0.8V drop occurs, the 13V output voltage will be 21,700V. With the T.M.Works Direct Power Harness, the primary coil voltage drop is at most 0.2V, that would mean a 13.6V input with an output of 22,700V. That is approximately 1000V gain in output when compared to the OE harness.
This would mean that the Direct Power Harness is able to keep the vehicle close to its original performance.
FEATURES
Suppress a voltage drop.
Ignition coil to reduce the burden.
To prevent high rpm when misfire.
Ignition power up.
Our unit comes with the special blue color insulation to beautify your engine bay and make it feel more powerful.
BENEFITS
Protect ignition coil
Fuel saving
Improve low ~ mid rpm torque
Better engine response
100% Hand Made in Japan
BUY NOW
t-m-works-direct-power-harness-for-toyota-daihatsu-perodua-4-cylinder-engines-1.jpg192.6 KB · Views: 228 -
t-m-works-direct-power-harness-for-toyota-daihatsu-perodua-4-cylinder-engines-3.jpg108.8 KB · Views: 184 -
t-m-works-direct-power-harness-for-toyota-daihatsu-perodua-4-cylinder-engines-2.jpg112.9 KB · Views: 179
