Stock Block 4G63T Rebuild
3rd GearPerformance House
Make the good stuff for hold 650whp on your stock block 4G63T 2.0L.No Stroker kit what we make it.With a good budget and engine realiable we run with Manley Rod,Forged Ross Pistons,Stock Crank and ACL Race engine and Rod bearing.You can save a cost,and get the stuff around RM 6500.Hope Everybody can do it what we done before.:biggrin:
that's a good news 4 turbo owners... less money more power...
Manley I tuff or H beam?
Manley xpencive than Scat.Scat have 2 time forging for metal with a good budget.Also he can do a forged rod same like factory rods.We can get the best price RM1600 for your door step.This rods can hold power 750whp with out no dramas.
Bump: Manley xpencive than Scat.Scat have 2 time forging for metal with a good budget.Also he can do a forged rod same like factory rods.We can get the best price RM1600 for your door step.This rods can hold power 750whp with out no dramas.
Bump: The forged rods are not coming from CHINA.Only the box from china.U can compare the material.China made have a rusty,but USA no.China is a good copy in the world.
6 bolt or 7 bolt?
Bro,
what is 2 time forging?
How do we compare material side by side , if it is from China or USA? by looking at the rust? All steel rust regardless where they are made from. The common steel that does not rust in the industry is stainless steel or aluminium. Care to share how to compare?
Bro,
You can compare if you ask the forged rods manufacturer for the mill certificates. On the mill certs you can see which country the mill is situated, what the properties make up the alloys.
You can further compare by conducting a bend test for the forged rods. See which one breaks first.
how about 4g67 already rebore to 4g63t spec.is it consider as 4g63t?can it use above mods?
Yes u can use.But the 6 bolt rods little bits xspencive compare with 7 bolt rods.6 bolt block cant make a high rev.U have to put the gurdle but the 7 bolt already have.
so for this case..how much the cost?
it is including the labour charge?
Is it the girdle that limit the 6 bolt high rev. ability? What if i use lighter piston and con. rod. which will cause lower stress to the crank during high rev.?
What exactly the function of the girdle and how high is high rev. for 4g63 engine? Is it rev. or WHP that determine the need to use girdle?
or it just an insurance for the expensive engine that will give you a peace of mind when running high rev or bigger whp....
it's act the rod ratio + piston weigh + rod weigh that determines how high u can rev your 4g63,girdle is just a solid insurance n a gud thing to have in ur build. I agree with jo1 on this :) cheers bro.
reliable..?....what is the full cost of that plus workmanship..?rm6500..?
RM6500 for 4G63 Block,Pistons,Rods,ACL Engine/Rod Bearing,Crank,ARP Head Stud and including Engineering work.(only Block assemble) maybe u can get the lower price in sunway shop.try the best.
Bump: RM6500 for 4G63 Block,Pistons,Rods,ACL Engine/Rod Bearing,Crank,ARP Head Stud and including Engineering work.(only Block assemble) maybe u can get the lower price in sunway shop.try the best.
hmmmm pricing and all sound ok....hmm....
will check budget after cny...kekek anyway ur shop is at USJ right...?
