replace ur starters, alternators and ignition distributors
we specialised in reconing and supplying of starters, alternators and
ignition distributors, quality products with 1 month warranty..
marvyn
016-228 3182
Guys...i'm starting my projector retrofit project and would like to ask if anybody has done the wiring before? as u all know, H4 works by turning off the low beam light when hi beam is switched on. this wont work...
gents, need help on Tial 44mm with 1 bar spring. i'm using tulang ikan, cheapo solution for boost control hehe. but the problem is the WG seems like struggling to hold boost really well even at 1.5 bar. it slowly...
er.. not sure does this being cover before.. anyway
wanted to ask all guru's here. I do know some scooby WRX do equipt with TD04 turbin. But is WRX TD04 same as the GSR TD04? i mean in terms of Turbine Wheel...
