Spoon Caliper fits 15 x 6.5in +35mm
Johnny_9
KL
Spoon Caliper fits 15 x 6.5in +35mm rim?
or must we use a
15 X 7in +43mm rim?
Depends on the rim..
A guy here once had issues with caliper clearance on a 5-lug 16" Advan RG with 40ish offset.
It's not due to the outer edges, but rather the hub design, where the spokes meet, that are thick, so could not clear the calipers properly. His other set of TE37 with similar offset did not have such issues.
So it depends on the wheel design as well. thick spokes and too little offset could pose a problem with spoon calipers.
Anyone use (15x6.5inch +35mm) rims
Regamaster
with Spoon Calipers?
Newbie Question
at least offset 38
When u say "at least" 38mm offset - does that more than 38mm i.e 15 x 6.5 +40mm
or lower than 38mm offset (i.e. 15 x 6.5 +35mm offset).
I thought the lower the offset the more the wheel will "stick out from the body" and therefore there will be more clearance for the bigger caliper.
Err... you bought spoon calipers ?? How much ?
I'm getting one also...but i didn't check the fitment for my RIMS......
So....if mine is 17" x7 offset +43 ok ar ???
Sorry tumpang sikit ar !
wow everyone change to spoon caliper, so rich. but i still prefer avantech 6 pot :_:
Spoon Caliper
Better check fitment. U can use a spacer but with Big rims and the slammed look u may get fender rub = solution : New Rims..
Thanks...will check it out once the shipment arrived ~
Nope, i bought it used from hk.... today he juz sent it via express.....
Any custom tax on it ar ?
well bro if you cant find the rim to fit with your caliper you can always sell it to me.
Spoon Caliper + SSR Type-C (15 x 6.5inch) +35mm - surefit one?
The spoke design looks like alot of clearance.
