Soundproof Material for 2 WHOLE doors only RM50
khguan
4,000 RPM
Seri Kembangan
Insulflex® Heat and Sound Insulation Material
http://www.zerotohundred.com/newforums/attachments/exterior-and-body/173897d1228358105-soundproof-material-for-2-whole-doors-only-rm50-insulflex-sa-01-jpg
http://www.zerotohundred.com/newforums/attachments/exterior-and-body/173898d1228358105-soundproof-material-for-2-whole-doors-only-rm50-insulflex-sa-02-jpg
- Great for soundproofing your car for a quiet and comfortable journey.
- Makes your car feel solid and pleasant to drive.
- Proven to reduce NVH (Noise Vibration and Harshness).
Dimension : 3ft x 4ft x 1/4" thick (6mm)
Material properties:
- Self-adhesive backing
- Lightweight material and easy to use
- Very flexible
- Very low water absorbtion rate
- Fire retardant material
Recommended to use on :
1. Doors
2. Front bonnet
3. Rear trunk lid
4. Boot floor and walls
5. Floor pan
6. Front fender / wheel arc
7. Roof
8. Engine firewall
*One sheet is enough for 2 doors or a wira front bonnet.
Price : RM50 per sheet
Anyone interested can contact me at 012-270 8685 (Guan).
My location at Seri Kembangan/Serdang area. COD at other locations can be arranged with bulk purchase (5 pieces and above)
***Courier service is now available for Peninsular and East M'sia. Just add RM10 for first 3kg for Peninsular or RM30 for 1st 3kg for East M'sia (air freight). Minimum order for mail order is 2pcs.
Sound Dampening Material also available, pls click ---> http://www.zerotohundred.com/newforums/interior-and-cockpit/257346-%2A%2A%2A-insudamp-sound-dampening-material-%2A%2A%2A.html
bro...just wanto ask if want to do to my waja how much will it cost?
neezam 016-3317884
hi,
i sell material only. For waja.. n for most cars.. pls refer to below:
1. 4 doors - 2pcs
2. Front bonnet - 1pc
3. Boot floor and walls - 2pcs
4. Floor pan - 2pcs
5. Rear trunk lid - 1/2pc
6. Roof - 1pc
7. Engine Firewall - 1pc
How much would it cost to install on a Saga BLM?. All 4 doors and front and back bonnet.Best price ? How long would it take. Location to install? Include installion cost?
well i dun usually do installation bcos i do not have a place to install...
4 doors need 2pcs.. on-site installation labour charge is RM100 for 4 doors. Installation will take less than 1 hour.
For easy deal pls call me. Thanx! :nurse:
bro, is this material really can cut down sound? or only heat reasistence? cos. Insulflex is do heat risistence product is it?. is this product heavy?
yes... this material will reduce noise form outside the car quite effectively with proper installation.
this Heat n Sound insulation material... can insulate heat up to 110 degrees Celcius before loosing performance...
dude wat the different between 1st pic and 2nd pic??look like not same material
btw if do for whole wira need how many pieces:wavey: and how much??pls pm me...thx
bro what about vibrations?
Bump: if i get from you can help install ar?hahaz...teh tarik ten cups la...
socaiwai,
the 2nd pic was taken a few years ago as the insulflex that time was rough surface... but now all the insulflex i sell are with smooth surface.. :smokin:
whole wira will need 8pcs like that... just call me for best deal.
ettm,
vibration can be eliminated if u install correctly..
i dun usually do installation as the labour is not cheap... 10cups?? not enough leh.. for 4 doors installation u need to treat me about 70-80 cups only enough eh.. :biggrin:
Jhri,
i would recommend u guys to DIY as it is much cheaper...
well perhaps u can goto Pit Stop service center in SUnway Pyramid parking... they got do installation with a reasonable price. :smokin:
